DeanoJS
New Member
I had a bad case of diesel bug in my fuel system last year which caused my to replace the fuel pumps (x2), injectors (x10), dump the fuel, clean the tank, new fuel lines and filters and start again.
Within less than 10 hours of running on the new setup I started getting rough idling problems, cutting out and hard starts. I have just had the injectors and pumps removed again and sent to a professional shop for testing, to be told that they are gummed up with "polymerised fuel". Apparently a problem that is becoming more common due to bio-content and desulphurisation and exacerbated by infrequent use.
Just wondering if any others are having similar problems and if so are there any recommendations to prevent it from happening again.
