davel
Over the weekend I discovered I was unable to pump out the holding tank. My arrangement is a manual pump taking waste from the tank to the outlet seacock to discharge below the waterline. The pump is not moving in exactly the same way you experience if the seacock is closed (it isn't!). As I had guests on board, I decided it best not to undertake too much investigation, however I did loosen the pipe to the inlet side of the pump sufficiently to enable air to enter the system. The pump remained immovable so I've concluded the blockage is either in the pump itself, or in the pipe downstream of the pump.
I intend to get down to the boat during the week to take a proper look and try to unblock it. The plan is to look firstly at the pump, and then move to the downstream piping where I suspect the blockage will be. I'm not looking forward to removing the pipe, which I suspect could be under a bit of pressure !
I was thinking of using one of those drain snake wires to try and unclog it. Has anyone had any experience of using one of those things on a boat? Any other ideas? Anyone fancy giving me a hand?
