blocked heads
jeremyshaw
18 Apr 2005
UK
Depends what's blocked it. Without going into the gory details, leaving it overnight can soften paper and tough turds. If it's more serious then it's probably a dismantling job.
It's possible this has happened because of a gradual scaling up, which does happen, particularly if the crew don't take care to flush out well. Urine leaves scaly deposits which gradually reduce the available bore.
billmacfarlane
Brighton
My 5 year old Jabsco blocked for the first time 2 weeks ago. It was blocked at the right angled bend on the outlet and was caused by loo paper despite the fact that I always use Aqua-whatever-it-is. It's obviously an unpleasant job but straightforward job to strip down and while I was at it I replaced the top gasket and valves.
