dunedin
I did the diesel filters on Sunday - the usual messy but relatively simple task.
Usually bleeding to the screw on top of the second filter does the trick. But this time it ran for about 60 seconds and then died. The documentation I have suggests I need to bleed the high pressure side by loosening nuts at the injectors, whilst turning the engine over. But there is nothing more to explain.
Any hints
* which nuts exactly - couldnt budge the ones I thought it should be, and loosening the ones on top of the units didn't work
* is this possible as a one man job ? to turn over the engine on my boat need to be in the cockpit, but nuts are down below ?
Any hints from the experts ?
Any hints
