JimC
Changed the bowl on my water separator and obviously needed to bleed the air out to allow the new bowl to re-fill. Other Lucas / CAV filter heads I've worked on have had a bleed screw accessible down a cast-in tunnel on top of the head. The Lucas unit fitted to my 2004 boat doesn't have such a screw, the tunnel is just a blind hole with no screw at the bottom. I had to bleed the unit by slackening off the central clamping bolt which wasn't ideal as it allowed fuel to seep out of the various circumfrencial joints. Has the bleed screw been value-engineered out of existence?
