Blanking off a Freeman 22 Mk 2 Toilet
ikga33
New Member
23 Jan 2006
Hi all,
I live on my Freeman 22 Mk 2 and the sea toilet has finally given up the ghost! I want to take it out and blank it off to replace it with a Porta Potti, so does anyone know the simplest and cheapest way to blank off the old one? Can I do it from inside?
Cheers,
Chris
G'day ikga33, and welcome to the forums.
Assuming this is a standard marine toilet you can just turn off the inlet and outlet valves on the hull and remove the old toilet.
If you need to remove or fill in the inlet and outlet thru' hull fittings, she will have to be lifted out.
Hope this helps
Avagoodweekend,,,,,,
