Ex-SolentBoy
Blakes seacocks come with a strainer to go on the outside of the hull.
My simple understanding was that you used the strainer for inlets, but left it off for outlets. A recent incident has made me rethink this.
On passage this week a friend found his engine starting to overheat. Correctly identifying a blocked water intake he was able to tie up at a nearby town and investigate. A plastic bag had been sucked into his seawater intake through the strainer. Hard to believe but true. I guess the bag was rotting.
Anyway, they managed to clear it by a combination of diving and fiddling around in the boat. The boat of course was fitted with a proper strainer inside the hull as well.
The point was made that if there was no strainer on the outside of the hull and reliance was put on the internal strainer it would be easy to simply poke a stick from inside to out.
On the either hand, with no external strainer the flow into their would be greater with associated increased risk of sucking bags and other debris in, albeit to hopefully get caught by the internal strainer.
What do you think?
What do you think?
