aidancoughlan
We've just launched 2 weeks ago, and noticed that our Lavac (working well since install 2 years ago) is not drawing in fresh sea water for flushing, though the pump seems to be working ok - I took it apart and cleaned out limescale in the pump just in case, and it is pumping out water from the bowl (lid up) ok.
However, when pumping out with the lid closed (sealed), the vacum is supposed to suck up fresh seawater to fill & rinse the bowl & outlet pipes - this it will not do.
Checking the Blakes website/manual suggests the following:
(1) Inlet seacock closed: Open inlet seacock and check that the outlet seacock is open as well.
(2) Failure of vaccum: When the seat and lid are closed and the
pump operated, the bowl should be sealed for around 30 seconds, i.e. you cannot lift the lid. Anything less indicates excess air bleeding into the system. Check the condition of the seat and lid seals.
Are all the hose clips tight? Check air bleed plug is in place and that
the hole is not too large.
(3) Inlet hose looped greater than 5 feet (1.5m) above water line.
In this instance it may be necessary to fit a non-return valve in the inlet hose just above the water line. This maintains a head of water to facilitate the initial syphoning of flushing water.
(4) Inlet pipe or seacock inlet outside the boat blocked:
In this condition the bowl will seal. Check seacock by closing it, removing the hose and then turning on. Check inlet hose for blockage.
It's not (1) above - the (blakes) seacock is in the open position (unless its possible for this to have failed in some way ?
It's not (2) above, it pumps out ok, and the seal seems solid (cant lift the lid for a minute or two)
Its not (3) above, the hose doesnt loop that high - and it was working the last 2 seasons.
So... if the seacock is blocked, whats it likely to be blocked with, and what's the best remedy? I've seen previous posts on search talking about divers, or taking off the hose and poking it clear from inside the boat (with water gushing in?). The access is very restricted, so I'm reluctant to remove the hose from the seacock unless absolutely necessary - Is there any short cut I can try before getting to this?
