navrep
Active Member
Not done this sail this way before, thinking of going this Saturday, but wondering how lumpy the wind over the tide might be through Wallet? What is your experience? Thanks
There has been the occasional drift net set in the Wallet, variably monitored by a fishing boat and usually during the working week. Not something to be overly worried about but worth keeping the VHF on as there will be some chatter if there is one out there.
Leave the blackwater around 10:30 ish , keep the land on the left , as Pete says watch out for pot markers , don’t cut the corner to much after the Naze and keep out the way of big ships
Have a great day !
You may wish to observe the navigation marks. Don't sail into Thirslet spit, Cocum Hills, Colne Bar, the Eagle etc. the buoys will keep you safe...
Not forgetting the Harwich Shelf buoy inside the harbour. A lot of yachts have done so over the years and spent some time regretting it, as you will be coming with the ebb the tide will be lowish when you get there, so very important!
There won't be much water over the shelf in the hour it might take from Stone Banks. I regard it as a half-tide passage, though I will happily cut inside the buoy.Not that it's an excuse to miss the Shelf buoy, but if you follow my advice to go for LW at Stone Banks, the flood will br set by the time you get to the Shelf.
Peter.
The shelf is seductive as you see the harbour opening out before you!
I always think...
Stone banks - Languard Point and follow the yacht track. I admit I cut the corners and trespass in the deep water channel but not when anything's moving in there!
You can flirt with the shallows as much as your nerves allow... when we're day sailing we play fast and loose with the depth. At the end of a long sail, when you're tired, I find following the channel leaves the brain free to do other things!
