Black spots
Hoolie
3 Mar 2005
Hants/Lozère
I thought Dettol was people stuff, and Dettox more of a cleaner, comes in a pump spray bottle ? Much the same though.
You might think that, but they've re-named it! I have a plastic squirty bottle of the stuff in view as I type this :)
I know the name changed 'cos we've used it for years.
2Tizwoz
23 Jun 2005
Northumberland
'Dettol Mould & Mildew Remover is specially formulated with a powerful bleach to easily remove even ingrained mould and mildew. It kills 99.9% of bacteria and viruses. No need to scrub-contains active bleach.
Contains 2.59g Sodium Hypochlorite per 100g'
According to the Dettol website here
Its intersting to compare the different product offerings from Amazon
As usual the 'Marine' product is exceptionally expensive but here's a website that compares a few.
The conclusion being that plain beach works best. The test doesn't describe the longer term effect on different sailcloths however.
2Tizwoz
23 Jun 2005
Northumberland
Sail care from the UK Halsey newsletter
'SAIL CARE
If you can't bring your sails in for winter service, here is what you can do yourself.
SELF SERVICE
Sails that have been used frequently, or in heavy weather, should be washed at the end of each season. Soak the sails in a warm soap solution for a couple of hours, then hose them off thoroughly. Make sure they are completely dry before folding. You'll need a big space to do this. If the sails are particularly dirty, add a small amount of bleach to the water before soaking. Dirty spots can be lightly scrubbed. Laminate sails should be hosed off, dried and folded. Try not to soak or scrub them.
STAIN REMOVAL
Blood and Mildew: Soak the stained area in a mild bleach solution for two hours; scrub lightly.
Rust: Rust removers are offered under many commercial names and are available at just about any hardware store. Just make sure you rinse the cleaned area thoroughly. One product that works well is Whink's Rust and Iron Stain Remover.
Oil, Grease, and Tar: Dab the stained area with acetone or lighter fluid and then rub the stain with clean rags. Once the stain is lightened, scrub the area with a detergent and water solution. Rinse all the acetone out of the material!
INSPECTION
Spread the sail out and look carefully at the corners. The corners are the highest loaded area on every sail. Check the stitching, the webbing and the layering patches. Make sure the stitching is sound, the webbing is not frayed or sun-bleached and that layers are not coming loose. Any fraying at the top of the boltrope on mains and genoas needs to be neatened up with a hot knife.
On mainsails, check all the slides and the webbing that holds them to the sail. If the main has a boltrope, check both sides of it to make sure there are not cuts in the tape around the rope. If the main has any full-length battens, make sure the Dacron tape around the boltrope is not worn. Look over the batten pockets for wear from scraping against the shrouds.
On genoas, check the back end of the sail carefully. The leech gets dragged across the shrouds and the front of the mast in every tack. Fittings on the mast like a radar, deck light, whisker pole fittings, loud hailer, etc, all act like claws trying to scratch and cut your genoa as it crosses the rig.
If you notice any wear on the sail, get it to your sailmaker for repair. Likewise, if you find any holes, weak spots or rotted webbing, get your sail back to your sailmaker for a professional repair.
Roller furling covers need to be checked carefully because they are designed to take the sun's abuse while protecting the sail. Along with absorbing the sun's harmful UV rays, furling covers get beat up in every tack because they are dragged across the rig. It's a hard life being a roller furling cover; therefore, check the cover's stitching and the integrity of the material. If you have a cover made of UV Dacron, look for cracks in the material, which are a sign that the cover needs to be replaced. The picture to the right shows how well the cover did its job. Part of the cover pealed up during inspection to reveal the clean, protected Dacron sail. Luckily this deteriorating cover was found and will be replaced before the sail goes back into service.
STORAGE
All sails should be folded or rolled in a manner that avoids sharp creases. Sails should be stored under well-ventilated, clean conditions. Dampness, which may encourage mildew should be avoided. Mildew does not effect the strength of sails , but mildew causes unsightly stains that are not easily removed.'
V1701
1 Oct 2009
South Coast UK
I get tiny black spots on a few areas inside the boat that get a bit damp now it's colder (bits that aren't yet insulated), I sponge clean them every few weeks with some warm water, squirt of washing up liquid and squirt of lemony bleach. If spraying and spray has bleach in it make sure not to spray cushions, etc...
Heckler
24 Feb 2003
