pcatterall
I posted 2 threads on this but we have moved on a step so I will ask for advice again and possibly the story may inform others.
Story so far.
Neptunian 33' cruiser based in Spain , 2x 50 gallon GRP tanks both cleaned 3 years ago. Starboard tank is the working tank port is just a store with fuel pumped across via the polisher as needed.
We are using road fuel
A year ago I noticed that both dip sticks were getting a hard tar like coating, I assumed that this was also coating the tank sides and was concerned that it would do my injectors and engine no good (Perkins 4108) I use the all purpose addetive from marine 16 but only in the starboard tank 2 months later the fuel had gone black , tried multiple passes through the polisher but no impact and there was no sign of it settling out either, there was no big or water fixable. We dumped most of the contaminated fuel but on refilling it went black within a month.
After several months we have returned ready to resolve the issue and armed with 5 micron filters for the polisher and a test kit from marine 16 .
First check was to examine the dip sticks........the port tanks still had the hard tar coating and the fuel was still clear, the starboard tank stick was clean but the fuel still grey/ black.
I believe that the addetive used in the starboard tank has dissolved the tar which I guess is asphaltin and it is held in fine suspension in the fuel. I have read that the particles are so fine that they will's pass harmlessly' through the engine, this is borne out to some degree by the fact that repeated polishing passes have no effect ( in the past it has cleaned the funniest fuel).
I propose to use the new 5 micron filters in the polisher and even f that doesn't work will use the fuel on the understanding of what I read and also because the recommended filter for my engine is 10 micron so what passes through multiple passes through my 5 micron filter should be fit to use??????
What's the feeling guys???
Story so far.
