Albert Ross
In short .. my previous two Autoprop anodes (about £27+ each) lasted only a couple of months each. (No, no shore connection etc. and we were on a swing mooring). So I thought I’d add a hull anode (Yes, I checked for electrical continuity from anode to engine to shaft to prop .. all good).
Anyway, I fitted a new zinc prop anode and the afore mentioned hull electrode (which was aluminium) and was advised that the little zinc anode on the prop would inevitably fizz away as it tried to protect the aluminium hull anode that was only about a metre away.
Everyone I asked said “you mustn’t fit dissimilar metal anodes”. “ Zinc is less noble than aluminium and will be electrolysed first.”
Anyway, ten months later we lifted the boat. The prop anode (Zn) was not only still there, but was hardly spent at all. The aluminium anode on the hull was however, well corroded and about 50% used up.
Zinc is higher on the galvanic series than aluminium and should therefore have been used up first.
However, aluminium is higher (more reactive) than zinc on the electrochemical series (in seawater).
Why did my aluminium anode appear to protect the zinc one?
A nice man in the Chandlery at Troon Marina just said “anodes .. it’s a black art”.
What is going on?
What is going on?
