Yesterday I tried to use Blakes SP-106 epoxy resin to seal bare plywood in my engine bay. The stuff went properly syrupy in the mixing pot and stuck nicely to the vertical surfaces I was coating, but after a few minutes the coldness emanating from adjoining parts of the fibreglass hull cooled it down. It then started to liquify again and run down the plywood! I tried to warm it up with a fan heater, but it began to rain heavily so I closed the hatches. Despite wearing a proper vapour mask, stuck in a small boat crouched in the engine bay using a fan-heater like a hair-dryer on this noxious mix of chemicals, I started to go all dizzy.
The resin that had already dripped off the ply onto the cold GRP hull went even more runny, so I was using cloths to mop it up. Try as I might I couldn't heat the hull sufficiently with the fan-heater to get it to set. I then threw open the main hatch and burst out to get clean Southampton air into my lungs, but I had to make several more forays into the cauldron to ensure the epoxy on the plywood walls - if not the hull - had set. Eventually I packed my stuff and locked up the boat. Don't know what I'll find when I return in a few days....
