bird poo prevention idea for sailing and power boats
tcm
11 Jan 2002
Caribbean at the moment
IMHO, birds poo on the boat when they are perched on it - the number of birds on the wing which manage to hit a boat is v small. So most bird pooing is done whilst you are away from the boat, and whilst birds perch on the thing.
My tests so far have been with a balcony in central london, and with a powerboat. For the flat , i simply rigged just three pieces of string at a high level which foils their flying-in area. Result - no nice landing zone for the birds and hence no more bird pooh on the balcony.
For the boat, I run strings from a forward flagstaff on the pulpit at the bow down to various points on the guardrails. I run other strings from the radar mast down to stern rails. I could keep these on all year, but it's only needed for autumn really.
For a sailing boat, the same thing can be done, i think : first make a sort of "cat o' ninetails" from thinnish cheap string or I suppose fishing line. Take several (as many as you like) long pieces of string/line each about as high as your mast. Tie them all together at one end in some bodgy knot, and raise the lot up a spare halyard. Then pick out each line and tie it to somewhere on the guardrails bow stern and sides.
Don't bring the lines straight down - deter birds from flying through/close and landing on spreaders by taking a line around a spreader/shroud on stbd side (say) then forward around genoa perhaps and tying dwon to the port side for example, making a bit of an aerial "web" - and one which deters birds because it is not so easy for them to see/fly around as the thick lines/shrouds which support the mast.
For this reason, *thin* string (kite string is long, strong and plentiful) which the birds only see at the last minute is the key- they can allow for thick shrouds and the mast, for example. V thin garden wire is also good, tho more expensive and harder to store it's less prone to tangles.
They realise that your boat has tricky last-minute hazards and stay away. You won't kill the bids - they learn to stay away very quickly!
There doesn't need to be loads and loads of lines - one every few metres will deter them from landing. About ten for a 35 footer i think wd be fine. But of course, the more the merrier, as many as you can be bothered putting up i suppose! For the flat, i put quite a few lines up to start but eventually found that i needed fewer, so perhaps there's an element of training the birds to avoid your boat, and for your boat to stop being favourite spot as they "do their rounds" - after which only a few are needed.
Advanced users will be able to work some clever routine perhaps with elastics+hook tied to the lower end so the lines can all be rigged/derigged from guardrails in a few minutes.
As always, i wd love to hear of any success stories with this. I got nowhere at all with cd's or owls - the real deterent is making flying/landing on your your boat physically risky/painful for a bird on the wing looking for a perch.
Tried the cats cradle, then had to move the boat in a hurry......
As I stumbled over the lines rigged from the boom to the guard rails, I was thinking there must be a more elegant solution! It would have detered any burglars though. I'm sure there was a similar test once in the Crystal maze?
You ideas are very sound. Never use fish netting around a boat. To find a seagull dead or even worse not dead, tangled in the net is 'orrible and dangerous to try to remove if it is alive.
Yourn ideas are good although for me i9t is always a compromise between the tediousness of raising deterents and putting away before sailing versus the tediousness of cleaning up. Usually it is easier to clean up. If you move the boat often they seem to stay away and of course some locations are worse than others by often only 50 metres. It is spring here and one trick I have to do is stuff some rag up the boom to discourage the martens (or is that martians) from nesting in the boom. good luck olewill
It does work and very well, apparently black line is best, they see it and veer away. I've seen it done before in gardens, to protect ponds and crops. They will find easier roosts and food. I still prefer my method, but then I'm a bloodthirsty devil!!
You can hang a few balls on mast before Christmas and that is it! /forums/images/graemlins/grin.gif
Now seriously - idea is very good!
our solution is to get yourself a couple of cats we have and have no problems with birds i did find though by getting married the birds keep away anyway
All that string ??????? Much easier to use one piece of string only with about 6 of those free CD s attached along its length and flying somewhere above the boat. Much easier to take down to go sailing!!!!
John
There is one undeniable solution to this and it has nothing to do with anything you hoist, fly or spray your boat with.
The way to prevent birds crapping on your boat is to make your neighbours more attractive. When you leave, nip on board the neighbours boat and leave some dead fish or fish heads, some blackberries and to keep the ducks happy some granary bread.
It may even be worth hanging a bird feeder from his boom, though you need to know you will arrive before him the following weekend so you can remove all the evidence.
The problem with this is that bats will still crap on your deck, and bats are a protected species... oh gawd what have I started?
hahahahahahahahahahahahaha
You don't need a boat you ageing redcoat
You need one of these
isn't that you in it?
I used to chuck slug pellets into my neighbours gardens. All my slugs up and left as these pellets contain something which attracts slugs.
I Don't use slug pellets any more though as they kill hedgehogs which eat the poisoned slugs and snails.
