Bimini fixing question
SeaDave
18 Jun 2007
Surrey
From faffing about at speed, my front bimini fram has pulled the fixings from the screen surround out. It's an aluminium screen surround I presume.
Would a larger self-tapper type screw suffice to fix this again do you think of is there a better way of fixing the mounting plate to the surround?
Many thanks and apologies for the mundane/stupid post.
They're often just held with self tappers, so it seems reasonable. Can you get access to the back, if so then bolts, with washers or a back plate will always be better, but if you can't, then what other option do you have?
I can't access the back of the nut/screw so I guess self tapper it is.
I don't think there is any other option - I just didn't want to miss some trick that a forumite had discovered!
I am glad you asked that questions as I was going to post similar. Two of the studs on the outside of our windscreen have corroded and snapped off - nothing to hold the canopy onto. (Electolysis between the aluminium windscreen and S/S studs I think) If they are self tappers than I wil have a quick go at drilling and extracting them, if that doesn't work because of corrosion then drilling and screwing in new self tapping studs
