roly_voya
Doing final fit out on a 35ft ready for long distance stuff (been living aboard around uk for a while but cant decide on bilge pumps. Given that everything I possess will be on board not sinking is a priority and a large power pump seams a good idea just in case. Looking at potential flooding rates if I loose a seacock or prop shaft seems to sugest something in the order of 50-100gal/min. Just to compound things she is a traditional wooden boat with a very deep bilge sump and only limited access because tanks and engine also live down there. So lift is about 5ft and pipe run to transom would be about 20ft. Looked at engine driven and problems with fitting pump to engine, also don't like relying on starting the engine as it may be flooded or at least the belt might be because deep narrow sumps initially fill quite quickly so thinking of a 4 or 8000 gal electric job. Any ideas and what have others done? /forums/images/graemlins/confused.gif
