mcalan
So. The bilge pump stopped working and on examination I found a loose wire. Simple I thought just reconnect it but no still not working. Remove pump and connect directly to the battery and yes it works.
There is a bilge pump push button reset switch in the panel but it does not appear to have tripped.
The reset switch looks like a Klixon 10 amp thermal circuit breaker but am having trouble locating one.also why would it trip if it was just a loose wire?
Is there a way to test this unit
I’m thinking of removing it and connecting the two wires together to see if that get the pump going .
