Bilge Pump Testing
essexboy
30 Nov 2004
Essex
Hi, I have a small concern and need your advice please.
On my previous boat the bilge pump had a float switch,
and I had a ritual before leaving the boat,
1 Switch pump to manual to make sure it worked.
2 Go below, turn off seacocks, lift float switch to make sure that works.
3 Go home and rest assured.
My new (to me) boat has a Johnson sealed switch with no moving parts,
so I cant test it, and I always have this little nagging doubt !
Any ideas ?
Any ideas ?
Hold a wet rag over the contacts?
or.....
chuck some water in the bilge!
I would change for a float switch immediatly as they are more reliable, I have never trusted those type of water sensing switches, you can also test a lot easier
I recently fitted one of these to my boat - if its the same as yours its easy to test its working. There are two circles marked on the side of the switch - you just put your fingers on these circles and after a few seconds the pump should start.
I don´t see any reason why this type of switch should be any less reliable than a regular float type switch.
More info here:
http://www.johnson-pump.com/JPMarine/products/bilge/ultimaswitch.html
You should also be aware that some more elderly members of this forum are upset by people posting about bilge pumps. :)
Bilge pump testing
Hi, Thanks for the replys, I think during the winter when the boats on the hard I will
see if a float type switch will fit, If not then I might change the switch on a
regular basis, say 2 years.
