Bilge pump switch
gljnr1983
30 Oct 2010
Loch lomond
Should the the light on the seaworld bilge pump switch stay on when switched to auto?mines is doing just that which i think is stupid and will drain the battery.Could i have wired it wrong?
Glad it's fixed.
My bilge pump control lights up when the pump is running. It has a single switch that turns it on manually. The auto float switch is always enabled - under what circumstances would you *want* water to accumulate in your boat without chucking it overboard?
Glad it's fixed.
Oil/fuel in the bilges ?
But I suppose you could always turn off the breaker or pull the fuse ...
Exactly - it's a pretty rare need so pulling fuses is an acceptable solution. The fuse holder is right above the switch for this reason. Far better than someone switching an auto mode off by mistake.
