Bilge pump polarity
pcatterall
2 Aug 2004
Just installing an electric pump ( as none fitted on 'new' boat) I am fitting a 2000 gph pump and a manual/auto panel with alarm ( so two float switches upper one doing alarm)
The pump diagram shows positive through float switch to pump and the panel wiring shows negative is used through float switch to pump.
As long as I get the actual pump polarity right does it matter??
Thanks as ever!
nimbusgb
22 Oct 2005
A long way from my boat! :(
www.umfundi.com
If the negative side is switched you have the pump floating at 12v. If water gets in to the electrics then the potential (sorry ) for serious electrolysis is high.
Perhaps not the end of the world provided its contained to the bilge sump on a glass boat but if it gets up to the level of underfloor fittings, through hulls etc it could be really bad.
lovezoo
23 Feb 2005
Citta del Vaticano
www.myspace.com
As others have said the negative side of the bilge pump should go to battery negative and the positive side should go through the float switch and a fuse to the positive side of the battery. Don't wire this through the isolator as it should always be on.
