PaulJ
I have been conducting some experiments prior to installing a bilge pump in my 39ft long-keeled boat.
Plan A had been to install the pump just under the floor boards in the cabin and the discharge skin fitting as high as possible under the gunwale. This would mean that the pump had to suck the water though a height of about 3ft and then pump it a further 6ft.
My experiment with a bucket of water and fixing the 1 1/2 inch pipe about 9ft up showed that this configuration is simply not practical because it is extremely hard work pumping the water through that height and the rate of flow is just not adequate.
So Plan B was developed which involved taking the discharge hose up to the same height but then bringing it down again about 3 ft in the hope that the syphon effect of the piece of pipe coming down would reduce the pumping effort required. Alas this had no effect because the water ran out of the pipe faster than I could feed it with the pump so air went up the pipe and there was no syphon effect.
The only other solution I can think of is to have the discharge skin fitting just a little above the waterline so that the water doesn't have to be lifted so far and a seacock in the discharge pipe to prevent an ingress of water when the boat heels. I am not keen on the idea of putting a seacock in the discharge pipe because it is one more thing to do in a panic situation and there is always the danger of forgetting to open it. There is a non return valve in the pump but these valves always allow a small amount to flow back over time and anyway I wouldn't want to rely on that alone.
My questions are these... Firstly, to the surveyors out there, is there any regulation that says you can't have a seacock in a pump discharge pipe? Secondly, has anybody got any better ideas?
Oh, and before anybody points out that I have to have a pump which can be operated from the cockpit...... I do have one but it discharges through the transom so there is not the same problem.
I would welcome your thoughts......
