Gordonmc
Since I put the boat on a mooring I have been careful about the bilge pump and its float switch, to the extent I replaced both in the autumn and added a solar panel. Part of the routine on opening up the boat is to check operation by manually lifting the switch to activate the pump.
Luckily at the weekend I paid more attention and did a visual check on the pump. On lifting the float the pump did its thing, but I noticed water being disturbed at the base of the pump.
The plastic spigot had cleanly broken off the body of the pump. Because of the 1" pipe and jubilee clip the break was invisible from a cursory look.
Closer inspection revealed the spigot walls varies in thickness from a couple of mm to almost nothing.
Its a worry that if the boat had taken water the pump would have been doing no more than circulating briny.
No, the pump had not been knocked. No, I didn't keep the receipt.
