Bilge pump advice needed
dunkelly
28 Aug 2018
My Mac has a strange narrow bilge section in the engine bilge under the prop shaft that a normal pump won't access resulting in a permanently wet area that has a narrow access . Despite my best efforts I can't seem to cure the cockpit leaks into the bilge and would like to find a bilge pump that will lift from about 8 inches down via a tube . It's only about half a bucket full but it's really annoying . Currently I use an oil vacuum pump to extract it manually but would either like to automate it via an automatic system or at least have it switch operated . The access is about 3 inches across by 4/5 inches long and narrows as it goes down . Anyone any suggestions .
Look for a diaphragm pump, such as are used in pressurised water systems on boats as these are also called self priming..
