Bigger version of Barton shroud cleats
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I have discovered that Barton make neat cleats which can be attached to the shrouds. One is good for the flag halyard and the other has a big circle which is good for the shackle of the spinnaker halyard
http://www.bartonmarine.com/products-special-cleats.asp
However, these gadgets only fit wire up to 8mm in diameter. My rigging is a combination of 10mm and 12mm.
Does anyone know of a company that makes something similar that will fit bigger wires?
TudorSailor
I can't see any reason why you couldn't simply drill out the Barton cleats to take 10mm or 12mm wire - there's plenty of plastic on them and there's space between the clamp bolts.
I'd echo pvb's remarks.
A good thing about the 'ring' version is that the flag halyard can be run through it in a continuous loop, so it can't possibly escape.
The shroud cleats were strong enough to hold the lazyjack lines on my 32-footer for the best part of 10 years...with no evidence of UV damage, despite much of that time being spent in sunny climes.
