NLOM1
I've just taken on a 22ft hull which has been left in the sun and wind for at the last 2 or 3 years. All the ribs seem OK but there are significant see through gaps between the planking especially towards the bow. It would seem that these sections have been previously caulked and sealed with red lead. The small gaps in the mid section and towards the bow have been sealed with a black rubber-looking compound whichhas dried and is falling out. All I have done so far is to scrape off flaking paint and put 2 coats of primer. I next intend to check all copper nail plank fixings and relace all bolts with silicon bronze. Cannot decide best action for sealing hull. I am a cpmplete novice but reckon these are my choices in ascending order....
1. Using screws and flexible compound, fix soft wood battens on the inside. Caulk with cotton and Pur-flex. Might be able to remove battens after hull has taken up?
2. Use a router to take off the bevels on the planks and epoxy glue softwood splines into the gaps?
3. Sink her for six weeks and re-assess ?
Any comments much appreciated
Norman
Norman
