A
Anonymous
I have a Dell Inspiron 8600 and a week ago, sometime (?immediately) after I had been transmitting on my marine SSB, on start up the laptop gave the error message that it could not recognise the ac adaptor, was running at one third speed and would not charge the internal batteries. I accessed the Dell forums and found that this is a common problem and is almost invariably due to a faulty mains adaptor. Since I have full accident and extended warranty cover I phoned and was sent a replacement which was delivered next day by courier to the marina office. This cured the problem immediately.
1. Could the SSB radio transmissions have caused the fault? I don't know but I will always disconnect the power adapter and work on internal batteries when transmitting, from now on. I suggest you do likewise, whatever the make of your laptop, as the transmitted power levels from an SSB transmitter are enough to heat food, let alone blow small components.
2. I found that the non-Dell 12V converter that I had bought (and thought I had tested) gives only a limited functionality - the processor runs at one third speed and the internal batteries will not charge when connected via this dc-dc converter. The reason for this is unclear - I have searched the newsgroups and Dell fora and there are various theories; most people think there is an ID chip. Maybe, I don't know. Anyway, with hindsight, I should have paid a little more and bought the offical Dell converter. Indeed, I will probably invest in one now and use the other one for other electronic bits and pieces on board.
