Better line for my lazy lines
pcatterall
2 Aug 2004
Have just about sorted my lazy line configuration, it seems to contain the dropped sail ok and the whole lot will pull forward to stow neatly under the boom when not required.
I used 3mm polyester for the line but it seems very 'floppy', tangles easily and unravels like mad when cut.
Previously I have had a load of 3 or 4mm platted ( octoplat?) line which had quite a stiff handle ( the sort of stuff that you can knot but then untie!) and I would like to obtain this to redo the lines.
What have you found best for lazy lines, do you recognise the sort of stiffer platted line I refer to?
Thanks all
