DeeGee
Just a recap:
My Beta 28hp used to chew up the v-belt and make much black dust. After reading here that Beta now fit a polyVee belt, I got the kit from Beta (orrible price, but...) and fitted it last winter.
The results are everything that I had hoped for. The belt does NOT keep losing tension with little use, no dust and little** signs of wear.
** The belt shows a little edge-wear, and this is probably due to my not following instructions carefully enough. It is important to completely clean the original crankshaft pulley before fitting the over-pulley, if not it will rotate with a little eccentricity. I was in a hurry, noticed it wasnt quite perfect and called it a day, I will be refitting that pulley this winter.
