christoph
I re-engined with a Beta 3 cylinder BD722 some 5 years ago and had no problems until this year when I Re-aligned the engine to help prevent the eating up of cutlass bearings. The alignment went OK, or so I thought. To get the optimum alignment required the raising, slightly, the front of the engine on its mounts. After that, when motoring and closing the throttle a severe vibration set in. The normal tick over speed, as set in the factory is 650RPM where all is fine. Now it on closing the throttle it stops at about 900-1000 RPM where an incredable out of balance type vibration occurs. I assume this is a primary balance problem due to the 3 cylinder nature of the engine. Briefly pushing in the stop button usually slows the engine to its normal 650RPM and no problem. Also clicking the engine into gear and the extra load will slow the engine to its smooth tick over state. I've double checked all the obvious, cables, clamps etc and all is fine. All the problems started after re-aligning the engine a little so assume this is the root of the trouble. I spoke to BETA and they have no idea but suggest the tick over is too low, I think 900RPM was suggested, although 650RPM is just as the factory set it. Also 900RPM is at the point where the bad vibration sets in. They did suggest putting spacers under the engine mounts, these would be about 10-12mm thickness. I haven't done it yet but unless somebody out there has a solution I'll try that and see what happens. Has anyone had a problem with vibration on 3 cylinder BETA's or any other 3 cylinder engines? Any help would be much appreciated. /forums/images/graemlins/confused.gif
