Crinan12
I have had an issue with my beta 16hp 2007 engine that I can't get to the bottom of.
When the engine is cold, for the first 2 or 3 minutes it sort of 'breathes' - i think the term is 'hunting'. The revs fluctuate slightly. When the engine warms up it is fine and runs normally. I am not sure if the video shows what i mean.
Co pilot suggested that the engine is drawing air in upstream of the lift pump and when the engine is cold it takes some time to dispel the air. It said to pump the lift pump lever immediately before starting and if that cured the problem it would confirm an air leak. I tried that but it is just the same.
Any thoughts?
Thank you
Any thoughts?
Thank you
