Habebty
Anyone fitted this combination and have comment on perforamnce/maintenance etc. (particularly 20hp and Seaprop).
thanks
thanks
I’ve had this combination from new, installed over 10 years ago. Have had several issues with the oil seals leaking leading to emulsification of the ATF fluid in the saildrive. First time it was sorted under warranty. Have had one of the ring bearings fail and that left me with reverse only. Fixing the issues involved lifting the boat out and in the case of the failed bearing meant moving the engine to get the saildrive out. Apart from these 3 incidents it has worked faultlessly.Anyone fitted this combination and have comment on perforamnce/maintenance etc. (particularly 20hp and Seaprop).
thanks
