silverdawn
Hi All,In my present boat I have a Beta 20Hp engine year 1998 also my previous boat had the same engine year 2001, both created large amounts of black belt dust, speaking to Beta they advised to update the belt system with their conversion kit which comprises of new pully wheels and a wider toothed belt ,these are fitted to engines from about 2005 onwards.
The kit cost about £150.00 which I dont have spare, however on looking at the Beta website
they suggest that lack of ventilation to the engine compartment ie less than 200cm2 could cause black belt dust due to excessive heat around the alternator area.
The engine front access cover is in the saloon a factory finished fibre glass cover which is insulated and purposed made to deaden noise and prevent fumes /flames from entering the cabin. the only way I can introduce ventilation around the alternator area is by drilling two 100cm2 circular holes and covering them with metal hit and miss vents which could be opened when running the engine.
Other than the belt dust the engine run perfectly,So do I drill my perfect engine cover to (maybe) get rid of the belt dust or do I leave well alone and just change the belts more frequently.
