RogerLS
New Member
I trying to grt the right pitch for my Kiwiprop attached to a BD722 and am engaged in doing a lot of checks.
My problem is that if I run the engine at more than 2400 rpm, the engine temperature rises till it frightens me ( 95C max so far).
The cooling water flow rate is about 25 litres/min. ( above Beta's minimum of 20 l./min.) The maximum speed in neutral is 3500 as against the original 3600 rpm but I can only get 2900 rpm. with a boat speed of 6.1 kts. in forward gear with the temperature rapidly rising. This year the back of the boat is dirty with a sooty material I assume to be carbon from incomplete combustion.
The raw water impeller is new the inlet water filter clean and the heat exchanger clean as well.
The thermostat opens completely in near boiling water and closes properly when cooled. I've looked at the previos threads on BD722 thermostats and found them useful.
Now 6kts. is perfectly adequate for a boat with a waterline lenbgth of 25 ft. at rest and considerably more when running fast but not if the temperature goes up and up.
Has the forum any advice?
