Ammonite
I've recently been trying to figure out why my Beta 20hp was filling the cabin with fumes and think I've finally found the solution. My engine dates from 1995 (so not sure how applicable this is on later models) but there is a short length of rubber tubing from the last injector which connects the injector to the fuel return pipe to the tank. It's a pretty flimsy affair (roughly 5mm id, 9mm od) and mine had perished at both ends (on the underside where you couldn't see it). I reckon it's been dripping diesel onto the engine for ages but I haven't noticed it because it gets burned off when landing on the hot engine. Suggest you check yours just in case.
