aidancoughlan
I've a newly installed 25hp Beta (last year), and noticed this season that <u>when I leave the berth she wont pass 1,000 revs even at full throttle. When I throttle back and forward she still wont go past 1,000 revs, but when I throttle back to neutral and then full forward she is fine. </u>This behaviour has repeated itself consistently at least the last 5 or six times out this season. Once she gets "unstuck" she is fine, powers the boat along at around 6 knots easily (though only reaches 3,000 revs, not 3,600 max revs - the prop may be slightly over-pitched).
Any ideas why this might be ? Supplier had a look today & was puzzled - has never seen this before (it behaved as described on queue). He looked at the engine while I was demonstrating this & the morse lever etc is all working ok - he then reckoned that maybe the "rack" might be sticking (although he hasnt seen this in a new engine before). He reckoned I am a bit easy on the engine (which is probably true), and recommended working it a bit harder, accelerating faster on the assumption that this may loosen it up.
The only other symptom I can describe is that when we drive away from the berth we have been noticing quite a bit of vibration on the tiller. I think this might be our Kiwi prop sticking after the initial reverse out - it hasn't been greased yet after it's first year, had a reasonable amount of fouling when we lifted out, and the blades (especially one) is stiff to turn full movement (though still no problem to turn by hand). When I throttle back to "unstick" the 1,000 revs limit, after accelerating again the vibration is gone. Could these be related ? If the Kiwi blade somehow stuck at 90% to the water, could the pressure be so much that it loads the engine enough to stop it passing 1,000 revs ?
(BTW we've noticed bad reverse performance lately, and on lift-out today we find that the "reverse rollers" have fallen off the Kiwi prop after one season, not impresed ! However, caught Andy in the Vectra Marine office on Saturday his day off, and he rushed to the post office to send replacements hopefully for Monday, so can't complain. He reckoned they had another customer who had this problem as a result of a rope wrap, though I don't think we've had one . I just mention this in case anybody knows this prop and might connect it with the engine performance.
Any thoughts appreciated...
