yodave
Hello,
We have two relatively large diesel tanks onboard our old GRP yacht. It would take us four years of typical usage to empty the tanks. Having just cleaned these out, I'm considering mothballing one of them. I don't want to make the mothballed tank redundant, as we may decide on another long trip one day.
Balance-wise, the tank I would keep in operation is on the opposite side from the water tank (which sits alongside the tank I'm considering mothballing).
Both tanks are mild steel. They've been cleaned to the best of my ability, but there are areas I can't reach particularly well. At a stretch I can just about reach all four corners of the bottom of the tanks with a paint scraper. The bottoms aren't in as in good nick as the rest of the tanks - they're rusty. I think they're still pretty solid, but far from perfect.
So the question is; keeping in mind that I want to be able to recommission the tank for future use, what is the best way of mothballing the tank?
Many thanks
- If I leave it as it is, will condensation form inside and lead to water continuing the rusting process?
- If I put a gallon or two of diesel in there, will that help, or will condensation form more quickly and lead to a layer of water under the diesel, which will again continue the rusting process?
- Can I somehow treat the rust and then leave the tank empty, or perhaps add a gallon or two of diesel?
- Should I avoid mothballing and just keep both tanks in service?
Many thanks
