stuhaynes
Alternator: 24 volts rated at 60 amps
Domestic batteries: 4 x 110AH wired in series and parallel to give 220AH @24 volts
Starter batteries: 2 x 110AH wired in series to give 24 volts
Most of the time we are on marina power, charging the batteries and supplying 'domestic' needs from 10amps @ 230 volts.
We're about to spend more time away and looking at the the best way of utilising the alternator power. I know that from previous questions I've asked, our battery bank isn't big, though I thought it must be last year when we bought it!
I can hook up the two 110AH starter batteries into my domestic bank (they're only a year old and had virtually no use, which will increase capacity, but how to wire them for best results? Also, if I do this, what would be the best AH batteries to replace the existing starter ones?
Last year (before replacing all 6 batteries) I had 1 knackered battery and one that I took off my car (to give me 24 volts for the starter motor), at the time I had no choice! It worked a treat. Spun the old engine like a good un! If I add the 2 starter batteries to my domestic bank I have very little room for 2 more starter batteries so I'm looking for suggestions as to the smallest sensible batteries I can replace them with.
Engine is heavy industrial, 60 years old, 30HP diesel and about 2250CC.
The smart charger option is to give us the max performance while cruising to avoid excessive genny use whilst stood. I still have to spend loads on the boat, even without altering the charging method. I'm looking for something reliable that will look after the batteries and not cook the bank account.
Your considered opinions very welcome...
