NPMR
The unit in which is fitted the engine control on our Jeanneau (5 years old) is a pear-shaped aluminium casting, in two pieces, that clamp round a stainless steel post next to the wheel.
The paint (baked on) has mostly come off (complained to Jeanneau inside warranty period but no interest or help) and now I am doing something about it! It turns out that there are 6 threaded bolts (sitting in a threaded hole in one side) holding the two sides together and as you can imagine, with the seawater around, they were seized pretty solidly. I got 4 out with effort but the last 2 have had to be drilled and smashed out! (I won't bore you with the pain and agony of trying to drill in a confined cockpit space using a battery hand drill).
I am now going to have the 2 aluminium sides re-sprayed but the question of how to rejoin them once complete is to be decided. I will not put threaded s/s back in - obviously, but what would be the best way to remake the join, that needs to be robust enough to take the working of the morse control?
Drill out the holes and use a nut and bolt of some material that wont react with the aluminium? Put a plastic sleeve in and use s/s nut and bolt? Ideas please?
