blan321
Bought new moulded plastic gooseneck, guess it's a poly....moulding and has a moulding flashing around it for 2 halves of a mould, inlet fine at 40mm, outlet 50mm and want to use more 40mm hose on outlet. I can fit a reducing sleeve in stainless steel, what is best bonding agent to this plastic please. I have a 1/2 used tube of Tiger PU40, polyurethane adhesive. Thinking of using that.
Item looks just like the Force 4 item, bought in St Malo Chandler though.
I suppose I should also ask, is there a good reason for 40 inlet and 50 outlet? At moment 40mm hose all the way to the hull skin fitting.
