shortjohnsilver
I need to replace my batteries.
Recently had the occasion to use the bow thruster and had a massive drop in available power. So much so that the chart plotter indicated the drop to below 9.7 V just before it powered off and the bow thruster struggled. Engine running as manoeuvring into berth.
The thruster is linked to the domestic bank - two 110Ah in parallel. Separate starter 80Ah.
Ive owned the boat for eight years and the batteries have always managed very well and supported by solar.
I rarely use the bow thruster but this day the wind and tide through the berth was causing a problem. No worries, a bit of bow thruster and we’re all good. However, bow thruster kicked in and then performance dropped considerably. Looked to my new chart plotter and saw the volts dropping rapidly, then shut down at 9.7 V.
I suspect that the batteries need replacement and ask what batteries are best for the domestic bank. I’ll probably change the starter battery too.
Should I consider a dedicated battery for the bow thruster or remain with things as they are. I don’t really want the chart plotter and other instruments crashing every time I blip the bow thruster, or will the new domestic batteries retain sufficient capacity, that that does not happen? I did have the fridge on but as said engine running.
Ta Si
Ta Si
