Berth Condensation
AER
10 Jan 2004
Www.soloroundbritain.com
Can anyone advise what is the best syestem to reduce condensation on the underside of berth cushions. Everyone at the Boat Show says their system is the best !
MedMan
24 Feb 2002
UK
teall.name
We use the matting that is rather like a 30mm thick 3M Scouring Pad. It is very light, easy to cut to shape and works well.
<hr width=100% size=1><A target="_blank" HREF=http://www.yachtretreat.com>http://www.yachtretreat.com</A>
charles_reed
29 Jun 2001
I don't know if it's the best but it's certainly the most cost-effective.
Use the foil+polystyrene sheet you can buy from most DIY sheds, used for insulating the outside wall radiators. It costs about £8 to insulate a 6-berth boat.
ccscott49
7 Sep 2001
I have used carpet, which is effective, thick carpet, without foam backing! But Medman has the right idea, the mat stuff is excellent and allows the bunk to breath. Also make sure there are lots of holes beneath the bunk to allow more air to circulate, helps with any system you use.
ccscott49
7 Sep 2001
Majorca, Alcudia anchorage, august 2003, 45 deg, 95% humidity and not a breath of wind, you think you dont get condensation and sweaty bodies down here? I have news for you!
