Benson Lock - "incident" and caution
TrueBlue
30 Apr 2004
Sussex
This is an issue for those not concerned about retaining the lock keepers....
Last Wednesday (20th. April) at about 4:30 p.m. we were about to lock through Benson going upstream when we noticed a following boat was not following us into the lock cut. His line of approach was not unreasonable given the shape of the channel at that point.
Gesticulations from me and the relief lockie (Steve) produced no particular response from the boat so I reversed back (no mean feat for my boat) to discover he was hard aground. Several attempts to free him (pulling from either end, breasting up and so on) made no difference.
SO I returned to the lock layby (it was about 5:20) to ask what the lockie wanted to do as he should be off duty at this time. He suggested running some water down in the hope of lifting him off / flushing him down.
The tail waters having bee raised a tad, I managed to drag him off slowly and all was well.
The whole process took until well after 6:00 p.m. The point of this discourse is two fold:-
Without the dedication of the keeper staying beyond his time - it was well past 5:00 before it was clear that the boat was in fact stuck fast, the occupants could have remained stuck there all night, there being little traffic going up or down to rescue the crew and passengers.
If in future lock staff are reduced or disappear altogether, then who would be available to assist boaters who get caught out midstream? The suggested "flying pickets" of weir management would perhaps not be appropriate in this sort of circumstance?
The sand bar downstream is well known and has in the past been marked with a starboard hand buoy.
It's no longer there.
The bar is only slightly off channel - so it's easy to get stuck on it.
I hope the owner of said blue "Linnsen type" cruiser moored at the Swan gets wind of this thread and makes his thanks known to the lockie at some point. I think the occupants were frightened (the eddy at that point threw both boats around somewhat) and hightailed it back home to the safety of his mooring).
For anyone else the Thames navigation is quirky if you stray outside the normal channel (even if you can find where the channel is ! ) and the thought that it is safe for anyone to use, even in times of low flow without some form of Plan B is mistaken. The boater in question was a beginner. Many boaters are only occasional users who never learn or care less about the vagaries of this particular River.
I too witnessed two incidents this weekend that gave cause for concern.
Whitchurch Saturday the 23rd, we had just secured in the lock with one other boat and the lockie had left the top gate open and started to pack up for the night, it was 2 minutes to 5pm. So a crew member from the other boat ran back to close the gates, at this point another boat was about to enter the lock but the guy effectively closed the door on them and said the lock was full, they were practicaly touching the gates with nowhere to go as the queue behind had moved up the layby. The gates were not completely closed so he tried to open them again, but as he had lowered the sluices the OOHP would not let him reopen them without going through the 10minute filling sequence. I shouted at the lockeeper in the hut to turn the power back on to let the boat outside in which he did, but the the guy didn't seem to know what to do anyway, my daughter ran over to help with the controls and he said to her " ish a bit confushing whne your hammered"
Sunday the 24th; Mapledurham was full and some careful packing was required, the lock was starting to empty when the lockie shouted at the large hire boat in front of me to watch his bow, the crew were not paying attention and looking away, I looked to see that the bow had moved over the steps and the D-fender down by the waterline had hooked up on the top step and the boat was starting to list alarmingly, being the nearest I ran straight over and just managed to push the boat over the edge and it dropped with some force into the lock:eek: the crew were all quite shocked when they realised what had happened and it could have been a lot worse, Lawrence the lockie had run straight to the sluices but Mapeldurham is a big lock and would have taken a while to reverse.
There really is no way the Thames can run safely during peak times without lockies on duty, I fear there will be a lot more incidents this year.
Lock assistants
We had a problem at Mapledurham on Sunday when the lockkeeper was at lunch which was irritating rather than anything particularly serious. Approaching from the downstream side I had seen a couple of boats move into the lock and was about 50 metres from the lock when the gates were closed on us. I was a little surprised as I hadn't seen that many boats ahead of us. When I walked up to check I could see that there was plenty of room for us at the back of the lock and probably at least two or three more boats if the other boats had moved up a little.
We were not in a hurry and there was no queue behind us at that point so it was not too much of a problem, but the boats in the lock all looked like they had experienced crews and they really should have known better. It would have caused a real hold up if it had been busier.
On the way downstream through the same lock on Monday afternon it was again on self service when we got to the layby. I offered to take over from the lady operating the controls so she could go back to her boat at the back of the lock. I noticed that she had left her husband with the stern line only attached and the bow line loose so that the front of the boat was swinging across the lock as the water rushed in. They managed to secure it sideways across the lock so no damage was done, but it was a little alarming nevertheless.
I have always felt that the concern about locks being on self service was exaggerated as all it needs is a bit of common sense, but this, and the other incidents mentioned here, suggests that if the lack of assistants continues through the rest of the season, particularly at busy times, we could be in for some real fun and games. I hope that this was just a case of early season shortages.
Its good to see that the lock staff are appreciated.
The threads all indicate that there is an underlying potential
Health and Safety issue.
How lone will it be I wonder, before a nasty accident occurs?
About time that the E A takes issue and appoints enough staff to
fully man the river in busy times. Usual maliday I suppose, to many
Chiefs and not enough Indians,
It might be an idea to get a few of those "chiefs" out on to the locks for a complete weekend, not just the hour they may spend inspecting, then let them go back to their ivory towers to cogitate.
More than one lock keeper has mentioned to me that they are worried about a serious incident occurring very soon.
A very nice lady
returned my call this afternoon about the lack of a marker buoy and said there was one in place (well there was last year and this was my first trip this season) but she said it had gone missing.
She will be on patrol over the weekend and will replace it.
So sorted pro tem.
Come to think of it much the same happened last year, the buoy went adrift end ended up on the opposite bank - there's quite and eddy in the weirstream - even when the river's on low flow.
This last weekend a Team leader and driver were very much in evidence - working the locks and at lunchtime!
I was impressed.
EA seem to be listening at last.
Probably not senior enough for Brayman though..
So sorted pro tem.
I was impressed.
EA seem to be listening at last. G
No, I was thinking of those who seem to make these weird decisions.
Yes we saw Carol doing her bit several times over the weekend, and with such good humor as usual.
