Beneteau oceanis 40 Rudder bearings
Dan Lee
New Member
1 Jul 2011
Cheshire
The helm has gone stiff on my 2007 Beneteau Oceanis 40 and I plan on changing the rudder bearings.
Has anyone carried this out or can offer any advice.
Thanks in advance.
Dan Lee
Think I would try oil / grease / penetrating oil on all the cables and other bits first. Cannot see why the bearings should cause the problem they will get looser as they wear and are lubricated by the water that they sit in .. Just a thought ..
as above I'd look at everything else before even thinking about the bearings, its not the autohelm is it?
Ian13
Thanks for the reply, I have greased the cables but noticed that there is movement in the rudder stock when I put the emergency tiller in.
I have just discovered that there was a modification carried out before I took delivery from new by the beneteau dealer which involves a plate being bolted to the stock apparently to secure the rudder.
Last season the bolts came loose and fell out, on discovery I retightened them but wonder whether the rudder has worn the bearings while being run out of plumb. I am also unsure whether the bolts holding the plate should be secured by nuts in the slot as they are now or above with washers.
I attach the photo if anyone can offer any advice...
Dan Lee
Jimi
Thanks for the reply.
I have disconnected the autohelm to eliminate it but the steering is still stiff.
The autohelm cut out on my last cruise I presume because it was working too hard due to the steering fault.
Dan Lee
All
See photos of installation of modification.
Dan Lee
Ian13
Dan Lee
no chance the rudder stock is out of alignment due to loose bolts tightened wrongly making it stiff, no chance of bent stock due to a grounding? the first pic seems to show the stock is not central to the emergency tiller hole?
download
Testmonkey
The bolts could be tightened incorrectly, there has not been a grounding but you are correct the stock doesn't exit in the centre of the hole.
Unlike your photo the drawing of the modification beneteau sent me last week shows the plate with slots for the bolt positions and not holes furthermore the nuts are secured inside the slots. The design you sent would hold the stock plumb unlike mine.
This is what is fitted to my boat. (see drawing from beneteau below)
Dan Lee
