Beneteau 381 shaft nut lock washer size
Heckler
24 Feb 2003
Just for the record, the 30mm shaft has a 20mm lock washer with an 8mm key tab under the prop nut. I struggled to find this info and had to buy a lock washer off Ebay using an educated guess. We have just moved it from La Linea to Bruces yard. Lifted after two years, we put Jotun Sea Queen on her then. Some light fouling with maybe a dozen 1cm barnacles scattered about. The prop was covered in a thin layer of hard orangey stuff, tube worms etc and some barnacles. The International Trilux was overwhelmed. At €30 a spray can I was a bit disappointed.
Am going to follow Vyvs idea this time.
