Heckler
For info, the prop on my Bene 381 with an MD22 engine is a left hand 16" by 16" on a 30mm shaft
Stu
Stu
3 bladed, someone has replaced the std Beneteau one, the box is the std MS2, don't know the ratio. The prop is bronze, the surveyor pointed it out, it gave a dull ring instead of a ting when tapped. Also there is no anode on the end of the prop as on the std one. She revs to 2700 with the stern dug well in at about 7 - 8 kts.Is that 2 or 3 bladed? Also what is the the gear box ratio ?
