Benetau electric Windlass Spares
peasea
23 Jul 2001
England
Can anybody please tell me where to obtain replacement make/break relays for controlling the anchor chain handling motor for a 36ft Beneteau?
Make of windlass would help. If it is a Lofrans then EC Smith is the distributor.
On the other hand it could be a Leroy, a Lewmar, Simpson Lawrence, etc etc.
Leroy Somer is a huge French manufacturer and windlasses are a minor product for them. Not even sure that they still make them, nor have I ever seen a stockist in the UK. Your best bet is Ancasta who are the main Beneteau dealers in the UK.
You may actually find that the relays are standard industrial items, but I don't know enough about them to advise.
Hope this helps
I suspect my B331 has the same unit. Mine was successfully overhauled by a mate.
He dismantled the thing and we saw deep pitting on the heavy copper contacts. He cleaned the contacts with a file, and reassembled.
It's been working perfectly for the last 2 seasons.
I would tackle the job myself now.
Good luck.
>>> ..... He dismantled the thing and we saw deep pitting on the heavy copper contacts. He cleaned the contacts with a file, and reassembled..... <<
This exactly what happened on our Lofrans relay many years ago. I stripped it down (incredibly simple!) cleaned/filed the copper contacts, and it's been perfect ever since - around 10 years now.
Well worth the very effort to check this out first before reaching for the wallet!!!
If rebuilding the contacts doesn't fix it, just go to your nearest supplier: a solenoid is a solenoid. We sell a particular make whose switches and solenoids are absolutely fine for exeryone else's windlasses and electric winches, too!
Thanks for your post, however I can't find a spec. or possible supplier . any info will be appreciated on 12volt solenoids.
Regards -- Peasea
