Bending oak
Little Rascal
28 Jul 2010
east anglia
Well I think it's oak, maybe teak? Perhaps you can tell from the photo...
I have a wooden guide rail for the sliding companion hatch that has bent/warped. It was taken off the boat by the previous owner for sanding and varnishing - which I am now doing a year or so later.
It's about 3 and a half feet long and roughly an inch out of true. I'm reluctant to just bolt it back on, as the boat is quite small and I don't wish to put that kind of strain on the hatch side. It's obviously warped because of it's L shaped section.
I was thinking I could soak/steam it and bolt it to a piece of 2 by 4 to straighten it. What do you think?
old_salt
8 Dec 2005
Cheshire, England.
Just set up a jig with a little bit of extra to counter the bend and clamp it up may be pour some boiling water over it from a kettle and leave it over night, un-clamp and have a look see and if under done increase the extra counter and re do if over done just leave free and let it reset it's self a bit then fix in place leave for a week then free it and see if it is mate-ting up without any strain to the hatch side.
SHUG
18 Dec 2010
E Scotland
OR you could get it into position and use a wallpaper steamer to heat it up as you tighten up the screws. You could put old blankets or sacks on top to retain the heat and steam.
AndrewB
7 Jun 2001
Dover/Corfu
It's not important but it looks more like teak or iroko than oak.
Agree it looks more like teak. It may matter somewhat. I used to find oak the easiest hardwood to bend, teak is harder to persuade but iroko very inclined to split.
