Bembridge entry tonight - any tips?
CalmSkipper
25 Aug 2006
UK
I'm planning my first entry into Bembridge tonight, 1.9m draught. Tidal calc shows enough water HW+/-2 (ish) so can make the entry before it gets too dark - Any tips and where is the best alternative if for some reason I have problems?
Steve Clayton
22 May 2003
Benitachell - Spain
www.aloeland.co.uk
Check the marker pole depth outside Bembridge. Re-check your calcs and go in on the rising tide. Know when you want to leave and again; come out on a rising tide.
If you can't take the bottom make sure you are on a berth with appropriate depth.
r_h
5 Jun 2006
West coast France, Solent + E. Med
www.rupertholmes.co.uk
With your draught, tonight may be a little ambitious for a first-time entry. Tides are on pretty much mean neaps at the moment - which gives HW height at Bembridge of only 2.4m over datum (the range at Bembridge is much smaller than that of Portsmouth).
If you do go for it, you'll need an accurately calibrated depth sounder and take it slowly - you may encounter spots with only 1ft (0.3m) under the keel.
Jobs_a_ good_ un
28 Jan 2005
home bristol boat where ever we end up
www.beneteau393.co.uk
The least depth is between buoys 2-3 they are at the start of the channel
the channel bends round sharply to the right after a couple of hundred metres
not all the port and starboard markers are in place I usually count down the buoys
Its a great place the little shop in the village is open till 8-9 each night
Theres a brilliant walk along the beach and through the woods to seaview
Have a good trip
CalmSkipper
25 Aug 2006
UK
Thanks all - and if I have problems getting in, whats the best alternativ overnight ioption from there (forecast is West backing southwest 4 or 5, occasionally 6.)
Whitelighter
4 Apr 2005
Looking out of the window
If the wind is West then the Acnhorage just to the north of Bembridge entrance is lovely. There is a pool which is deeper than the surrounding water, but is marked on the chart, which is quite close in. You will be in the lea of the Island, so protected from the wind. I think it is Seaview but could be wrong
fireball
15 Nov 2004
It is Priory bay ... could get a little lumpy in Wind over tide conditions though - with 6' keel you won't be able to anchor that close in ... quick options are: Porstmouth - Haslar, Gosport Marina or Southsea Marina .. if you want a nice anchorage then a run into Chichester Harbour would see nice anchorage at Pilsey Island (north of East Head) which will be nicely sheltered from the Westerly wind and good holding.
