davidpbo
I am fitting new acrylic windows which bed directly on the side of the fibreglass cabin.
The previous ones were bedded with tape originally. I did re-bed one with the wrong Sikalflex and that seemed to develop crazing quickly, another I re-bedded with a flexible butyl sealing compound.
The replacements are 10mm thick (previous were 8mm on the side and 10mm on the front). I went for 10mm all round so it came out of one half sheet.
Is the recommendation to use bedding tape or an appropriate flexible sealant? If I use tape do I need to use sealant around the screws/in the screw holes.
The fixings are interscrews and the originals anodised aluminium should I use the same (probably not anodised) or stainless steel ( The internal trim is aluminium).
Are Hadlow Marine Services still in existence? the link to there web site is not working for me.
The edges of the supplied windows weren't polished and have the bandsaw marks. Presumably it is wet and dry then a polishing compound, a liquid car polishing compound without colour restorer (T Cut is out) or abrasives. Could someone recommend one please.
I have to drill 90 holes. Pillar drill and slow I know, would I be better off with a steeper angle than a normal HSS drill.
