Bed
Csail
N/A
24 Aug 2005
Cardiff
Ok its not a boat but same design needed. I am going to put a double bed in the van but quite high up so what can i use to make it to keep the weight down.
Have just been thinking of a frame with a sheet of kingspan insulation board?
Kingspan wouldn't have the strength for the job and the metallic skin would stop moisture escaping.
A frame of Aluminium angle with pine slats would do the job. 2x1 on 4" centres would do the job if you add a central longitudinal slat underneath, screwed to all the transverse battens to spread any point loads.
